This command disables IPv6 route sharing.
| vr_name | Specifies a VR or VRF. If not specified, the current CLI context is used |
| all | Specifies all VR or VRF. |
By default, IPv6 route sharing is disabled.
This command disables IPv6 route sharing for the IPv6 address family and VR.
The following example disables IPv6 route sharing for the IPv6 address family and the VR of the current CLI context:
disable iproute ipv6 sharing
This command was first available in ExtremeXOS 15.3.
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
The ability to enable and disable ECMP for IPv6 is supported for all platforms.
